Problem with XBMC
jozweerd
I mapped a Hdd to media/hdd but when i copy the xbmc folder to media/hdd and than delete the xbmc folder on root
xbmc will not start, when i put the folder back on root xbmc starts. Is it necessary to put the xbmc folder to media/hdd
to not fill the flash or is it only for beta1/beta2?
And the xbmc folder is on my vu+solo2 on usr/share/xbmc is that right?
Using BH 2.1.5
Using BH 2.1.5
The XBMC folder like addons etc is located under /media/hhh and the directory trace is /media/hdd/.xbmc !
/media/hdd/.xbmc ---> where <.xbmc> is an hidden directory .
You can´t delete the XMBC directory on /usr/...., if you do that XBMC app don´t works! ( is like uninstall XBMC ).
So, if you have did that, you must reinstall the image to must able to use XBMC.
If you have a internal HD --> normally the /.xbmc is created on your HD
If you have a USB HD --> you must map first of all the HD like /MEDIA/HDD ( mount ), before run XBMC for the first time.
best regards,
Ok thanks xbmc is working now.
Only when i want to play some streams in the addon veetle i get the message gstreamer h264 decoder not available
so i get only sound but no picture, is there any plugin available for that?
