Probleme of Disecq c 1.2
laplace
Hello
I just bought a VU + duo.
I installed the image BH174 without problem.
By cons when I want to install a motorized dish I can not find
the parameters of commands DiSEqC1.2 same for the other images BH 170,172,173.
Could you help me find the solution to this problem.
Thank you in advance
Main Menu >> Setup>>Service Searching >>Tuner configuration.
For motorized DiSEqC dish you can use
Configuration mode simple
and put only Longitude and Latitude .
Of course you can use the advanced mode
but it is a bit complicated and you can chose DISEqC mode 1.2
