problemi con wintv nova stik 70019
artma65
ciao a tutti volevo chiedere se questo hardware funziona male solo a me oppure si può cambiare qualche impostazione o driver per migliorare le prestazioni.i problemi sono dovuti alla ricezione dei canali con squadrettamenti e sgancio di canale continui su moltissimi canali dtt,cosa che la A867 non fà anzi è impeccabile su tutti i canali.ho il box solo2 con bh2.0.1 rev A. queste sono le info registrate con putty ehci-brcm ehci-brcm.2: USB 0.0 started, EHCI 1.00
> hub 3-0:1.0: USB hub found
> hub 3-0:1.0: 1 port detected
> ehci-brcm ehci-brcm.3: Broadcom STB EHCI
> ehci-brcm ehci-brcm.3: new USB bus registered, assigned bus number 4
> ehci-brcm ehci-brcm.3: irq 75, io mem 0x10490500
> ehci-brcm ehci-brcm.3: USB 0.0 started, EHCI 1.00
> hub 4-0:1.0: USB hub found
> hub 4-0:1.0: 1 port detected
> ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
> ohci-brcm ohci-brcm.0: Broadcom STB OHCI
> ohci-brcm ohci-brcm.0: new USB bus registered, assigned bus number 5
> ohci-brcm ohci-brcm.0: irq 71, io mem 0x10480400
> hub 5-0:1.0: USB hub found
> hub 5-0:1.0: 1 port detected
> ohci-brcm ohci-brcm.1: Broadcom STB OHCI
> ohci-brcm ohci-brcm.1: new USB bus registered, assigned bus number 6
> ohci-brcm ohci-brcm.1: irq 72, io mem 0x10480600
> hub 6-0:1.0: USB hub found
> hub 6-0:1.0: 1 port detected
> ohci-brcm ohci-brcm.2: Broadcom STB OHCI
> ohci-brcm ohci-brcm.2: new USB bus registered, assigned bus number 7
> ohci-brcm ohci-brcm.2: irq 76, io mem 0x10490400
> usb 1-1: new high-speed USB device number 2 using ehci-brcm
> hub 7-0:1.0: USB hub found
> hub 7-0:1.0: 1 port detected
> ohci-brcm ohci-brcm.3: Broadcom STB OHCI
> ohci-brcm ohci-brcm.3: new USB bus registered, assigned bus number 8
> ohci-brcm ohci-brcm.3: irq 77, io mem 0x10490600
> hub 8-0:1.0: USB hub found
> hub 8-0:1.0: 1 port detected
> Initializing USB Mass Storage driver...
> usbcore: registered new interface driver usb-storage
> USB Mass Storage support registered.
> mousedev: PS/2 mouse device common for all mice
> i2c /dev entries driver
> Success! Registering the characther device success with 0
> blackhole initialised
> sdhci: Secure Digital Host Controller Interface driver
> sdhci: Copyright(c) Pierre Ossman
> sdhci-pltfm: SDHCI platform and OF driver helper
> usbcore: registered new interface driver usbhid
> usbhid: USB HID core driver
> ALSA device list:
> No soundcards found.
> TCP cubic registered
> NET: Registered protocol family 17
> lib80211: common routines for IEEE802.11 drivers
> lib80211_crypt: registered algorithm 'NULL'
> PM: CP0 COUNT/COMPARE frequency does not depend on divisor
> EBI CS0: setting up NAND flash (primary)
> NAND device: Manufacturer ID: 0xec, Chip ID: 0xda (Samsung NAND 256MiB 3,3V 8-
bit)
> brcmnand brcmnand.0: 256MiB total, 128KiB blocks, 2KiB pages, 16B OOB, 8-bit,
Hamming ECC
> Bad block table found at page 131008, version 0x01
> Bad block table found at page 130944, version 0x01
> nand_read_bbt: bad block at 0x000000fa0000
> nand_read_bbt: bad block at 0x0000064e0000
> nand_read_bbt: bad block at 0x00000be20000
> nand_read_bbt: bad block at 0x00000e040000
> nand_read_bbt: bad block at 0x00000e520000
> Creating 4 MTD partitions on "brcmnand.0":
> 0x000001f00000-0x000010000000 : "rootfs"
> 0x000001f00000-0x000010000000 : "rootfs(redundant)"
> 0x000000200000-0x000000900000 : "kernel"
> 0x000000900000-0x000000a00000 : "mac"
> UBI: attaching mtd0 to ubi0
> UBI: physical eraseblock size: 131072 bytes (128 KiB)
> UBI: logical eraseblock size: 126976 bytes
> UBI: smallest flash I/O unit: 2048
> UBI: VID header offset: 2048 (aligned 2048)
> UBI: data offset: 4096
> UBI: max. sequence number: 218
> UBI: attached mtd0 to ubi0
> UBI: MTD device name: "rootfs"
> UBI: MTD device size: 225 MiB
> UBI: number of good PEBs: 1792
> UBI: number of bad PEBs: 8
> UBI: number of corrupted PEBs: 0
> UBI: max. allowed volumes: 128
> UBI: wear-leveling threshold: 4096
> UBI: number of internal volumes: 1
> UBI: number of user volumes: 1
> UBI: available PEBs: 0
> UBI: total number of reserved PEBs: 1792
> UBI: number of PEBs reserved for bad PEB handling: 17
> UBI: max/mean erase counter: 10/5
> UBI: image sequence number: 1467785286
> UBI: background thread "ubi_bgt0d" started, PID 44
> UBIFS: parse sync
> UBIFS: recovery needed
> UBIFS: recovery completed
> UBIFS: mounted UBI device 0, volume 0, name "rootfs"
> UBIFS: file system size: 223477760 bytes (218240 KiB, 213 MiB, 1760 LEBs)
> UBIFS: journal size: 9023488 bytes (8812 KiB, 8 MiB, 72 LEBs)
UBIFS: me> UBIFS: media format: w4/r0 (latest is w4/r0)
> UBIFS: default compressor: lzo
> UBIFS: reserved for root: 0 bytes (0 KiB)
> VFS: Mounted root (ubifs filesystem) on device 0:14.
> devtmpfs: mounted
> Freeing unused kernel memory: 184k freed
> rtw driver version=v3.4.4_xxxx.20120730
> Build at: Feb 19 2013 15:02:55
> usbcore: registered new interface driver rtl8192cu
> NET: Registered protocol family 10
> procmk_init
> dvb_bcm7356: module license 'Proprietary' taints kernel.
> Disabling lock debugging due to kernel taint
> DVB: registering new adapter (vusolo2)
> bcm7335: hotplug_callback():
> Hotplug - status.connected 0
> [GP]:brcm_pwm_init
> brcm_demux_init: $Id: bcm7335_demux.c,v 0.6 $
> DVB: registering adapter 0 frontend 0 (BCM7346 FE)...
> [MPVR]: >> misc_pvr_init
> BKNI_P_GetTrackAllocEntry_resize: resizing from 4096->8192
> BKNI_Malloc(linuxkernel) top users:
> blocks, bytes, filename:line
> 694, 33312, magnum/portinginterface/vdc/7346/bvdc_bufferheap_priv.c:7
37
> 573, 128676, ../BSEAV/lib/utils/balloc.c:35
> 536, 21440, ../magnum/basemodules/mem/bmem_system.c:286
> 366, 43920, magnum/commonutils/mrc/7346/bmrc_monitor.c:940
(native) as /devices/virtual/input/input0> input: dreambox advanced remote control (native) as /devices/virtual/input/inp
ut0
> [LCD]: registered
> [CI]: registered ci0
> [DFP]: registered dbox fp
> [DFP]: Scart 9597 is found 4
> [SC]: registered sci0
> [SC]: registered sci1
> system_time_set wakeup mode get
> system_time_set wakeup mode get 0xc4
> fpga update driver loaded
> udevd (114): /proc/114/oom_adj is deprecated, please use /proc/114/oom_score_a
dj instead.
> WARNING: You are using an experimental version of the media stack.
> As the driver is backported to an older kernel, it doesn't offer
-sh: sd: not found
root@vusolo2:~# enough quality for its usage in production.
-sh: enough: not found
root@vusolo2:~# Use it with care.
-sh: Use: not found
root@vusolo2:~# Latest git patches (needed if you report a bug to linux-media@vg
er.kernel.org):
-sh: syntax error: unexpected "("
root@vusolo2:~# Custom Black Hole build
-sh: Custom: not found
root@vusolo2:~# WARNING: You are using an experimental version of the media stac
k.
-sh: WARNING:: not found
root@vusolo2:~# As the driver is backported to an older kernel, it doesn
't offer
> Use it with care.
> Latest git patches (needed if you report a bug to linux-media@vger.kernel.org)
> dvb-usb: found a 'Hauppauge Nova-T Stick' in cold state, will try to load a fi
rmware
> dvb-usb: downloading firmware from file 'dvb-usb-dib0700-1.20.fw'
> dib0700: firmware started successfully.
> dvb-usb: found a 'Hauppauge Nova-T Stick' in warm state.
> dvb-usb: will pass the complete MPEG2 transport stream to the software demuxer
> DVB: registering new adapter (Hauppauge Nova-T Stick)
> usb 1-1: DVB: registering adapter 1 frontend 0 (DiBcom 7000PC)...
> DiB0070: successfully identified
IR keymap rc-dib0700-rc5 not found> IR keymap rc-dib0700-rc5 not found
> Registered IR keymap rc-empty
> input: IR-receiver inside an USB DVB receiver as /devices/platform/ehci-brcm.0
/usb1/1-1/bh-rc/rc0/input1
> rc0: IR-receiver inside an USB DVB receiver as /devices/platform/ehci-brcm.0/u
sb1/1-1/bh-rc/rc0
> dvb-usb: could not initialize remote control.
> dvb-usb: Hauppauge Nova-T Stick successfully initialized and connected.
> usbcore: registered new interface driver dvb_usb_dib0700
> __clk_enable: network [1]
> __clk_enable: enet [1]
> bcm40nm_pm_genet_enable 00
> ADDRCONF(NETDEV_UP): eth0: link is not ready
> eth0: Link up, 100 Mbps Full Duplex
> ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
> svc: failed to register lockdv1 RPC service (errno 124).
> DVB: registering adapter 0 frontend 0 (DiBcom 7000PC)...
> [LCD]: unknown cmd 0x1015
> [CI]: CI interface initialised
> eth0: no IPv6 routers present
> kjournald starting. Commit interval 5 seconds
> EXT3-fs (sda1): warning: maximal mount count reached, running e2fsck is recomm
ended
> EXT3-fs (sda1): using internal journal
> EXT3-fs (sda1): mounted filesystem with ordered data mode
> Hotplug - status.connected 1
> Hotplug - connecting HDMI to display 0xf
> FE tune
> FE tune
> FE tune
> FE tune
> Hotplug - Disconnecting HDMI from display
> Hotplug - connecting HDMI to display 0xe
> FE tune
> dvb_demux_feed_del: feed not in list (type=0 state=0 pid=ffff)
> root@vusolo2:~#
> lsmod
> cat /proc/bus/usb/devices
