Problemi solo2 pctv 290e
dax
Ciao ho tutti, sul mio solo2 ho la chiavetta dvb-t2 in oggetto, che con la bh 2.0.1 funzionava senza problemi. Questa sera ho aggiornato alla versione 2.0.2a e da telecomando sono subito passato alla 20.2c. Ho infilato il tuner usb ed ho riavviato il decoder.
Ora i canali dvb-t non sono visibili e non è possibile fare la ricerca. Il tuner risulta abilitato e configurato con le frequenze dvb-t europa.
Ecco gli output richiesti, lascio la valutazione agli esperti
dmesg
[SC]: registered sci0
[SC]: registered sci1
system_time_set wakeup mode get
system_time_set wakeup mode get 0xc4
fpga update driver loaded
udevd (113): /proc/113/oom_adj is deprecated, please use /proc/113/oom_score_adj instead.
Linux video capture interface: v2.00
WARNING: You are using an experimental version of the media stack.
        As the driver is backported to an older kernel, it doesn't offer
        enough quality for its usage in production.
        Use it with care.
Latest git patches (needed if you report a bug to linux-media@vger.kernel.org):
        Custom Black Hole build
em28xx: New device PCTV Systems PCTV 290e @ 480 Mbps (2013:024f, interface 0, class 0)
em28xx: DVB interface 0 found: isoc
em28xx: chip ID is em28174
em28174 #0: Identified as PCTV nanoStick T2 290e (card=78)
em28174 #0: v4l2 driver version 0.1.3
em28174 #0: V4L2 video device registered as video0
em28174 #0: dvb set to isoc mode.
usbcore: registered new interface driver em28xx
        Use it with care.
tda18271 4-0060: creating new instance
TDA18271HD/C2 detected @ 4-0060
kjournald starting.  Commit interval 5 seconds
EXT3-fs (sda1): using internal journal
EXT3-fs (sda1): mounted filesystem with ordered data mode
DVB: registering new adapter (em28174 #0)
usb 2-1: DVB: registering adapter 1 frontend 0 (Sony CXD2820R)...
em28174 #0: Successfully loaded em28xx-dvb
Em28xx: Initialized (Em28xx dvb Extension) extension
__clk_enable: network [1]
__clk_enable: enet [1]
bcm40nm_pm_genet_enable 00
ADDRCONF(NETDEV_UP): eth0: link is not ready
eth0: Link up, 100 Mbps Full Duplex
ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
svc: failed to register lockdv1 RPC service (errno 124).
tda18271: performing RF tracking filter calibration
[LCD]: unknown cmd 0x1015
[CI]: CI interface initialised
tda18271: RF tracking filter calibration complete
DVB: registering adapter 0 frontend 0 (Sony CXD2820R)...
eth0: no IPv6 routers present
FE tune
FE tune
FE tune
/usr/bin/usbtuner -V
UsbTuner v0.3.12
lsmod
Module                  Size  Used by    Tainted: P
tda18271              38405  1
cxd2820r              13977  1
em28xx_dvb            16854  2
bh_dvb_core            87658  2 cxd2820r,em28xx_dvb
em28xx                79841  1 em28xx_dvb
videobuf2_core        26154  1 em28xx
bh_v4l2_common          8231  1 em28xx
bh_videodev          107279  3 em28xx,videobuf2_core,bh_v4l2_common
videobuf2_vmalloc      3024  1 em28xx
videobuf2_memops        1659  1 videobuf2_vmalloc
tveeprom              11737  1 em28xx
fpga_directc          57649  0
brcmfb                  1238  3
dvb_bcm7356        11704403  4 fpga_directc,brcmfb
procmk                  1445  2 fpga_directc,dvb_bcm7356
ipv6                  311826 12
cat /proc/bus/usb/devices
T:  Bus=02 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#=  2 Spd=480  MxCh= 0
D:  Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64 #Cfgs=  1
P:  Vendor=2013 ProdID=024f Rev= 1.00
S:  Manufacturer=PCTV Systems
S:  Product=PCTV 290e
S:  SerialNumber=000000102VXO
C:* #Ifs= 1 Cfg#= 1 Atr=80 MxPwr=500mA
I:  If#= 0 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=00 Prot=00 Driver=em28xx
E:  Ad=84(I) Atr=01(Isoc) MxPS=  0 Ivl=125us
E:  Ad=85(I) Atr=01(Isoc) MxPS=  0 Ivl=125us
I:* If#= 0 Alt= 1 #EPs= 2 Cls=ff(vend.) Sub=00 Prot=00 Driver=em28xx
E:  Ad=84(I) Atr=01(Isoc) MxPS= 940 Ivl=125us
E:  Ad=85(I) Atr=01(Isoc) MxPS= 940 Ivl=125us
cat /proc/bus/nim_sockets
NIM Socket 0:
        Type: DVB-S2
        Name: BCM7356 DVB-S2 NIM (internal)
        Frontend_Device: 0
NIM Socket 1:
        Type: DVB-S2
        Frontend_Device: 1
NIM Socket 2:
        Type: DVB-T
        Frontend_Device: 2
Ok grazie per gli output vedo di fare qualche sperimentazione in giornata .... dovrei avere il tuner DVB-T2 non impegnato sul Solo2 e lo piazzo sull'Uno (il box non è un aspetto vincolante)
Sorry for english
perhaps a restart of GUI before scan helps
see this thread http://www.vuplus-community.net/boa...-my-new-pctv-systems-nanostick-t2-290e.11667/
Come e successo a cyborgpunte, succede ogni tanto anche a me (diverso tuner DVB-T e WLAN sui due USB separati).
Non mi funzionano dopo il boot (dalla completa assenza di alimentazione) entrambi. Qundi se vedo LED dello stick della WLAN che e spento (anche DVB-T non funziona - confermato con le mie prove), non faccio gli sperimenti e faccio solo semplice restart e tutto funziona di nuovo.
Ho notato, che succede piu spesso dopo aver fatto la ricerca canali o l'update dell'image.
Ho spento il mio Uno (BH 2.0.2 Rev. C) e ho fatto un po' di pulizia coi cavi.
Nelle USB posteriori ho una USB stick da 1Gb (partizionata in 2) e una Wifi Linksys 150Mbit/s correttamente configurata.
Nella USB frontale ho la PCTV 290e connessa il cascata al tuner interno DVB-T/C di Uno.
Ho riacceso il box, riconfigurato il tuner B correttamente e ho lanciato la scansione: 369 servizi trovati e memorizzati.
Ho quindi messo in coda un po' di registrazioni ... sono arrivato a 9 contemporaneamente utilizzando il tuner interno e quello USB .... e per ora funziona tutto regolarmente.
Inizio a pensare che il tuo sia un problema di alimentazione del dispositivo USB DVB.
Se hai qualche suggerimento su come riprodurre il tuo problema, fammelo sapere.
Grazie a tutti! Questa mattina ho effettuato un reset di fabbrica e, dopo aver rifatto la configurazione iniziale, il tuner si è messo regolarmente a funzionare. Potrebbe essere un bug? Sono comunque sicuro che ieri sera il tuner non funzionava pur avendo il led blu acceso.
L' unica cosa che mi viene in mente per riprodurre il mio problema è la seguente procedura:
-flash via usb dell' immagine 2.0.2a
-update a 2.0.2c
-configurazione del box senza tuner usb inserito
-a questo punto spegnere il box, inserire il tuner, riavviare e configurare il tuner.
Se succede come a me avrai il tuner regolarmente abilitato e configurato ma a lato pratico non utilizzabile.
O.T. ho notato che nella infobar per i canali dvb-t viene indicata la frequenza ed il bandwidth (come indicato nel changeset): non sarebbe più carino se venisse visualizzato il canale? Nel caso qualcuno volesse modificarlo in proprio, su quale file della skin dovrebbe agire?
-update a 2.0.2c
Spiegami cosa intendi per "configurazione del box senza tuner USB inserito" ... senza tuner connesso, è IMPOSSIBILE impostarne le relative impostazioni come la zona geografica di riferimento che è fondamentale per un corretto funzionamento dello stesso.
Intendo la configurazione iniziale del wizard, ovviamente escludendo la parte relativa al tuner usb dvb-t
Io sono partito da una situazione simile ovvero il solo tuner interno configurato e sono andato successivamente ad aggiungere quello USB.
Per me, nessun problema.
Enigma2 elabora dal file terrestrial.xml la frequenza centrale del transponder (i standard DVB-T/T2 internazionali)
e non lo chiama "canale". Quindi infobar visualizza la frequenza da quale si potrebbe visualizzare ipotetico numero del canale, ma questo varia dal regione al regione (Europa, Australia, ecc.). Come la BH e fatto per tutto il mondo, ci sarebbe il casino nelle skin (ricalcolo no. canale dalla freq. centrale diverso per quasi tutti i paesi).
Magari se chiedi il mago delle skin Matrix10, ti potrebbe dare qualche dritta per la versione personale Italiana delle skin BH.
Ok, io ho riprovato ora ed ho avuto il medesimo problema. Benissimo, riguarda solo me (oppure il mio solo2). Per quanto mi riguarda rimarrò sulla 2.0.2a.
Grazie mille per la delucidazione.
All'inizio parlavi di 2.0.1, quindi con 2.0.2 Rev. A funziona? Se sì, configura tutto con quella, spegni completamente, riavvia, controlla funzionamento del DVB-T2, e fai l'aggiornamento a Rev. C.
Non precisamente, ho detto che con la 2.0.1 ha sempre funzionato regolarmente.
Si, con la rev a funziona. Se effettuo l' ugrade alla rev c dopo il riavvio smette di funzionare.
Ho provato perfino, sempre con la rev c, ad effettuare un reset di fabbrica. Riavviato il box, riconfigurato il tutto e tuner usb funzionante. Altro riavvio e tuner down.
Per questo sarei propenso a tenermi la rev a.
Rifatta minuziosamente la procedura. 2.0.2a, configurazione e tutto ok (dvb-t compreso). Spento completamente, riavviato ed effettuato l' upgrade a 2.0.2c. Dopo il riavvio tuner usb down.
Ho quindi effettuato un reset di fabbrica e, dopo le configurazioni del wizard, il tuner usb ha ripreso a funzionare. Purtroppo però dopo ogni riavvio il tuner muore.
Il fatto strano è che succede solamente a me...
Come è collegato il tuner USB al box?
Direttamente, alla porta posteriore. Non ho altre periferiche usb collegate, ho solamente un hd interno da 2.5'.
Potrebbero tornare utili gli output del mio primo post in condizioni di funzionamento ed in condizioni di non funzionamento?
La cosa strana è che con la rev c dopo in reset di fabbrica e riconfigurazione tutto funziona fino al successivo riavvio. Per questo escluderei problemi di alimentazione o altre amenità...
Hai provato USB anteriore? Se sì e fa le stesse cose, prova con un Hub USB autoalimentato. Potrebbe essere questione della gestione di alimentazione o timing delle USB interne o chiavetta con eccessivo consumo (piu di 500 mA).
Io proverei anche staccare HDD interno, ho il dubbio dei 5V interni.
In settimana vedrò di fare delle prove... Mi sembra strano il fatto che con la rev a non perde un colpo e poi con la rev c muoia.
