Problems channel cover
paztero1
Well I have in my decos (vusolose v2 and vu 4k) image BH 3.0.5 latest versions and I had to remove from my channel list the channel portal of the platform moviestar +, because every time I enter that channel it is as if it were restarted and return to the previous channel of the list, we can not have that channel listed.
I do not know if this is already commented by some side and if there is a solution to this problem, if there is one and you can inform me of this topic I will be grateful.
The problem is solved, but we should give the final solution and not have to change anything.
Thanks again.
