Problems I can't resolve! (VUO+Duo)
Norweger2
Hello everyone with a VU+Due + Blackhole 2.1.6.
I have been struggling with setup of satelite seeker and my Vu+ from New Year. And my wife looking for a divorce!!:shout:
I have ALL set up. LNB1 as the main input. I KNOW I am on my sat. Trying to see the strenght in the motor setup is not available. My channel list is from my computer.
The SNR is flashing from 0 to 90. I can never lock a sat. anymore. Finetuning is ok but not showing. I have changed ALL my connectors - bought a new motor and LNB.
Have any of you seen this before and what to do?
For me it seems to be a receiver problem. Any idea?
Thanks a lot to those who respond to me.
In my receiver? Just asking ask I have no clue. The antenna seeks and the channels are marked as I do have them. But no picture, I have never had such problem before and now I have been out of sat for 4 months. ave updated and bought all new. The receiver is next if I can't find out about it..
maybe you ave a "short" or some capacitors are gonne
if snr is flashing like you said, the possible causes are a short in some connector OR , and if that you must take your vu to service, one or some capacitors exhausted in the power supply...
If possible try your receiver on a friends, family members, dish, even a fixed one, this will tell you if there is a problem with the receiver.
If your receiver is fine I'd check your cable, and connections.
It is probably worth re-doing the connections, to the F Connectors, in case the braid has sheared off, this could explain the SNR going from 0-99%.
Thanks for the idea. I have changed my connectors except of one !! I'll do that and will go to the dealer. Thanks a lot for the effort answering me.
