Problems recording
efterlyst
I flashed my VU+ Duo with Black Hole 1.6.4.
Everything works great, excepts recording a programme.
I get a message saying "Couldn't record due to invalid service"
my Hdd is initialized and ok and time shift works.
I have tried both to set a timer and to record by pressing record button and tried different options when pressing record.. No luck.
I had the VTi image before black hole and everything worked like a charm there and i haven't changed any equipment since flashing black hole...
Does someone have an idea ?
thanks for the quick answer. Had a movie folder on the harddrive, deleted it and made a new one:/ still same thing. As you mentioned it i checked the locations for where the recordnings are saved, its all pointing to that folder too.
Edit, when i try to set a timer on a programme i get the message: "Channel not in services list" and they are obviously.
Seems that the channel you try to record have a invalid service ID.
If you use premade settings, update it or make a new scan of the channel of your interest.
Hello efterlyst
Please tell us if you resolve the problem ?
I have the same problem with a new Vu+Solo2 and BH 206
