Uno problems SNR after deep standby wakeup
@Mr.who : Try to use external DC injector device to supply a power to your LNB, respecting V/H polarisation voltage 13/18V. I suggest to use a power supply with adjustable tension/current limit. If the current will be more than 400 mA, you have problems with cables/LNB.
Matrix what you suggest me please?
There is a special electronic circuit for diseqc in the receivers.
It usually consists of a special chip/IC and FET / MOSFET transistor.
I suppose that most suffer these FET / MOSFET transistors.
But I not reapair satellite receivers already doing something else in electronics
Of course, the signal goes through the tuner.
So if you have a second tuner check with him.
In the second case, the problem is probably on the main printed circuit board,
and this diseqc electronic circuit.
Thanks Matrix, can you please share a picture for this special chip/IC and FET / MOSFET transistor on main printed circuit or on PSU.
Many thanks
Many thanks
Heh
No, I can not.Im sorry
There is not only one type of circuit.
I do not know what they use in the VU + receiver in what part of the receiver.
Maybe someone on the forum knows more about
aaa oki paolino,matrix thanks, the large probability fault is the single tuner of my vu+?
I hope that problem of tuner because tuner change is most easily than electronic diagnostic and electronic change.
conclusion: ca can be everything (PSU,electric component on motherboard) is ok, but the tuner is fault?
If diseqc electronics is direct in the tuner
then the greatest possibility for failure is in tuner.
However no guarantee.
The reason why this part can failure should be sought at a relatively high current to power the motor as well as in static electricity that could arrive there via cables.
Many thanks matrix, i haven't motor equipment, its connected directly to LNB.
i suspect static electricity arrived there via length of cables(long).
there is not overload protection on tuner which block the output tension?
Of course if this is the cause
I think there is some protection
But it is not protection in all cases.
Static electricity is very difficult for 100% protection
update:
when i returned at home i open the box, the tuner UP, SNR+ voltage Oki !!
it makes me crazy this tuner :/
I understand nothing
update:
i think that the problem is resolved,
cause: Sagem usb wifi adapter connected with 50cm usb cable, on cat /proc/bus/usb/devices there is 500mA consumption on usb wifi driver.
perhaps it cause PSU, Tuner or electric circuit overlod
when i disconnect the USB wifi adapter, i have no problem occurrence.
Thanks for all,
