Problems streaming from Solo2 (BH2.01)
spannerz
Guys
I have a problem that has been plaguing me for a while now.
I stream from a Solo2 box to various devices around the house (Raspberry PI and a couple of mobile devices)... recent versions of XBMC have been struggling with certain channels, it seems particularly ones for the kids (NickJr seems very susceptible)
The audio stutters and finally breaks (on the RPI).... initially I thought this was an XBMC issue (the same stream works fine with earlier versions).... however I have tested it with VLC and I am getting the following errors;
main warning: computed PTS is out of range (9204), clearing out
main warning: PTS is out of range (-38796), dropping buffer
main warning: computed PTS is out of range (9309), clearing out
main warning: computed PTS is out of range (50984), clearing out
main warning: PTS is out of range (50984), dropping buffer
main warning: computed PTS is out of range (51157), clearing out
main warning: PTS is out of range (27157), dropping buffer
main warning: computed PTS is out of range (51260), clearing out
main warning: PTS is out of range (3260), dropping buffer
main warning: computed PTS is out of range (51361), clearing out
The errors I am getting in XBMC are
09:32:04 T:3042779136 DEBUG: ------ Window Deinit (DialogSeekBar.xml) ------
09:32:05 T:3042779136 DEBUG: PrepareNextRender no buffer, out: 0, current: 0, display: 4
09:32:05 T:2702177376 DEBUG: Previous line repeats 1 times.
09:32:05 T:2702177376 INFO: COMXPlayerVideo - Stillframe detected, switching to forced 25.000000 fps
09:32:05 T:2620388448 DEBUG: Previous line repeats 3 times.
09:32:05 T:2620388448 DEBUG: video stream stalled. start buffering
09:32:05 T:2620388448 DEBUG: COMXPlayer::SetCaching - caching state 2
09:32:05 T:2620388448 DEBUG: OMXClock::OMXSetSpeed 0 buffering 0
09:32:05 T:2620388448 DEBUG: COMXPlayer::HandleMessages - player started 2
Other channels though are absolutely fine....
So it looks like the problem is actually the stream coming out of the Solo2
Is there any configuration applies to this functionality? Also, it would appear that the autoresolution doesn't apply to the streaming, can someone confirm....
Any help would be greatly appreciated (the other half is losing patience with my setup)
Thanks
Sz
