Problems using usb Dvb-C tuner
dorinineu
I am using Sundtek MediaTv Digital Home usb tuner with Solo2,everything works fine with BH 2.0.2 until rev.D.Now with rev. D and rev. E ,somethimes it wont start usb tuner when I zap on cable channel,only spinner moves.Not every time recover from that an need reboot from back button.
From Rev. D and Rev. E nothing has changed in the USB tuner section.
Yes ok,with rev C works fine,with D and E dont.Before rev.D never have had this issue.Problem is that after a while when I zap from sat tuner to channels on cable the usb tuner does not activate,to activate it it needs reboot,works for a while than agin same problem.
