Problems with 3d
Vu+ can not play correctly some types of 3d videos in spite of the TV can do this.
How to correct this problem?
Check your UID 3D Settings --> You have to install plugin if not installed! --> Use Speed Up --> turn <on> UI3Dsetup if it is OFF.
Go to plugins, change settings and test.
Best regards
+Check your UID 3D Settings --> You have to install plugin if not installed! --> Use Speed Up --> turn <on> UI3Dsetup if it is OFF.+
Alredy done. Unfortunately do not work with some MKV files
Use Enhanced Movie Center to try the MKV Files you have <---------------- Give it a try, if you don´t have tried yet!
