Problems with cams.
Sturmer
Hi from Marco.
I read a previous old post about problems with some cam.
Sadly, I am experiencing the same with a Viaccess cam, so I wish to ask if anything has changed meanwhile.
The same happened with an old Icecrypt cam, now useless (just tried to see if works).
I am stuck with a "init module" message in the CI assign page, and the common interface page shows "reset- Init-Init module-multiple channel support-high bitrate support".
Even when tried to reset or init, nothing happened.
Is there any way to solve this?
The cam works, as I have successfully used it with an old Digiquest P2000.
So I think it is a problem of compatibility with the Vuduo
Any suggestions?
Thanks!
