Problems with internet streaming
Rosin90
Hi, I hope someone knows how to solve this problem.
I can stream my vu duo over the internet, when I use port 80, but not when I use port 19172 or any other port. This becomes a problem when my NAS goes over and uses port 80. I do not know if it's possible to change the port of my NAS (Netgear Stora MS2110)
I have opened both ports in my router.
Thanks in advance / Rosin90
Into router configuration you can open one port 80 and redirect that only to ONE host on your internal network.
If you redirect another port (for example 14000) to 80 of your box there should be no problems at all because your router translate the port on both sides in the correct one.
Thanks, it solved the problem.
