Problems with latest drivers
Bruty
Hello VU Team!
I test drivers from 18.08.2010 to 08.10.2010 and still have bug with playback files from hdd.After few minutes playback freeze or scratchy.When move forward work ok and few minutes issues repeat.Test more files....Only work driver from 13.08.2010...
Hello VU Team!
What kind of files do you play from HDD?
I've played with success MKV and DivX with latest drivers (08/10/2010 - GCC 4.4.3) stored on CIFS share.
The only file type who cannot play (at the moment) is XVid MPEG4 but I have few files of that kind.
On the last Original Image (5.3) or third party image based on the same code, the media player work very well.
Which image you use??? Now I test DE 1.34c with latest drivers and work till now ok....Seems E2 problem...
I have the same problem. My hard drive is Samsung 1TB 32MB HD103SJ F3 sATA-2. My inside box image is VTi 2.1. MKV files work fine. There is a problem with AVI files. Will the problem be solved?
