Often find problems with playing movies on my VU+ solo. Mediaplayer starts playing normally, but after 7-12 minutes plays with breaks (jiters). When I stop (push pause) and start again, it plays normally some minutes or seconds and repeat playing with breaks.
- It does not depend on drivers. I tested diferent versions of driver on different kernels.
- It does not depend on mediaplayer. I testeв built-in and Enhanced (EMC), and Deluxe.
- It does not depend on movie location. Played with the same problem from local (USB) and remote (NAS) source.
- I checked free memory and don't find any problem. No find memory leak.
- I think that right codecs are present. Because some minutes all is OK.
Any suggestions? May be possible to change some parameter in Linux. Or change any library.
As an example of problem movie attached mediainfo.
