paztero1
Well I put this image (BH 3.6) in my vusolose v2 and in the vu + uno4k and everything is perfect but I see a problem that I did not have before and that I just realized now.
I have both decos with the same antenna and if I use one the other I have it in stamby with which the one that is working I can see the two polarities V and H, but in this last image there is a problem and is that although this in stamby a deco on the other only lets you watch the polarity in which is the stamby deco.
Also it happens to openBH and it is put in its section to see if there is any solution to this subject.
Also tell you that with the latest openspa 7.3.002 this does not happen and works perfectly just as in its previous version.
Is there any solution to this problem?
