Project-Valerie on VU+ Solo
sakisdvb
BH Lover
Hello.
The video playback is not always smooth, frame drop in almost every movie (mkv,avi).
This frame drop also happens with all other players i have tried on VU+ Solo.
This is a normal phenomenon for VU+ Solo ?
If it has something to do with Network speed can it be fixed?
All my .ts SD/HD recordings on local HDD, playing perfectly.
Also some avi movies don't play at all. (All players on VU+ Solo)
Any Help or opinions is most welcome. :D
P.S
How can I play a movie with two or more files with Project Valeria?
(Bob_the_builder_a.avi / Bob_the_ builder_b.avi)
Regards
Has anyone noticed random frame drop (VU+ Solo)
when playing a video (avi,mkv) from USB / HDD or Network?
This has to do with CPU performance ?
P.S. To play a video with two or more parts just add .cd1,.cd2 or .part1,part2 to file name.
(Bob.the.builder.cd1.avi / Bob.the.builder.cd2.avi)
No, i didn't notice it.
On my solo all seems to be ok.
Maybe you have many plugins on it?
Thank you for response. :)
If a plugin is installed but NOT running can reduce performance ?
Sherlock plugin is showing the VU+ Solo CPU load, but what is the meaning of numbers ?
And how can i get the maximum performance for playing Video ?
Regards
Regards
Yes, some plugins could make dec unstable.
About Sherlock i uninstalled it as i found my dec a little bit unstable when i had it.
How can i get the maximum performance for playing Video ?
Please be thorough.
Regards
I like media center that you can find in addons of BH, but i find nice also watching movies with default reader, that you you get pressing r botton.
