promblem
georgegr
Hi i have a router belkin n600 db and every time i connect my ultimo with original usb adapter the connection belkin-ultimo is not stable. I try to connect other devise and is all ok only with original usb i have problem you have any solution tnx for your time i need to connect usb with my router for HD streaming
ilmago
BH Lover
is the same with lan connetion? ip assignment automatic or manual? which bh do you have?
angelofsky1980
BlackHole Driver Specialist
... and what is your wifi dongle? what obstacles do you ave between router and box? have you tried, for test only, to connect the wifi dongle in the front USB port?
georgegr
Thanks to both of you for your time. I have 2 vu+duo long time i am fun black hole image i buy ultimo now and i know allot but i have this problem with specific modem router i connect my old router netgear 54g it is all ok but is only 54 m/s and i cant stream HD channel .I don't try in front usb because my router is nearly .I will try and post the results. In vu+ duo with specific usb dongle i have same problem angelofsky1980 my dongle is the original usb 1.jpeg I try WPA/WPA2 WPA WPA2 WEB BUT nothing .I change my router wifi channel but i have same problem .Sorry for my English
Matrix10
Thanks to both of you for your time. I have 2 vu+duo long time i am fun black hole image i buy ultimo now and i know allot but i have this problem with specific modem router i connect my old router netgear 54g it is all ok but is only 54 m/s and i cant stream HD channel .I don't try in front usb because my router is nearly .I will try and post the results. In vu+ duo with specific usb dongle i have same problem angelofsky1980 my dongle is the original View attachment 6741 I try WPA/WPA2 WPA WPA2 WEB BUT nothing .I change my router wifi channel but i have same problem .Sorry for my English
VU USB wlan dongle works great with my cisco router
So the problem is the router configuration or router.
A possible problem is the same position USB stick
and the USB dongle
which can cause interference with the USB wlan dongle.
Test Usb wlan connected on the front.
Of course the old router does not support the latest wlan N dongle speed 144 Mb/s
20Mhz Mode (tested ) and up to 300 Mb/s 40 Mhz Mode (not tested)
http://compnetworking.about.com/od/wireless/f/80211n-300-mbps.htm
georgegr
Thanks one more time .Now its all ok i test my usb dongle on the frond and works great. I put usb cable on behind and i removed usb dongle from other usb now works thanks to all for solution
