It is build into image allready. Menu -> Settings (first menu item),there should be a "parental control" (5th on list).
It does pretty much what you need. If problem persists, contact Caesar Milan.Maybe he works with kids too
I tried Cæsar before i posted here, but he could not fix the problem
But, ok, i will try again. I played with the parental settings, but the I could just "lock" the parental meny with a pin code. Setup and other menu's where wide open...
