Provider on 7 OE won't open
Mombik
Hi,
I have a Vu+ Ultimo with VTi image 5.0.
Would like to open transponder 11671V SID 0x1cd0 on 7 OE.
Scanning the transponder it don't open the radio channels. The only thing I see is the fire that is burning.
Can you give me some information on how to open this one. I have the same problem on 16OE. My old spider didn't had any problem to open this.
Thanks in advance for your kindly help.
there is no transponder 11671, you meant 11617 I think
try to use fresh list and check if that works
or
use dreamboxedit download your existing list and check category of these channels - make sure ti's radio, not any other
