ps3 media tomb
yummer
BH Lover
I've been happily streaming my vu+ over to ps3 using mediatomb. Something has gone wrong lately and I think the tuner server build has messed up. I have my directories as normal but now I have multiple 'same channel' selections which appear to be corrupted and don't work. Does anyone know where the tuner build is located so I can delete it and start again. Is it on the HDD? Many thanks
from memory it's in /media/net
But iirc if you disable tuner server, then enable it again, it will rebuild your database.
Cheers for reply Evo mate. Tried disabling tuner server and rebuilt it. Still same issue though bud. Sorry for upside down picture off mobile1379282649583.jpg
Think I've found it mate HDD/media/tuner. But like you said it disappears when you disable the tuner server. I've had a fiddle disabled everything again. Used ABM to scan for channels and disabled prefixes. Built tuner server again and started mediatomb. Weirdly its now worked ;)
Ahh yes thats it (I did say from memory lol).
Atleast you have it sorted now anyhow :)
