You could invest in a usb tuner to get same result m8. I'm sure @angelofsky1980 could point you in right direction of compatible ones for your device or work his magic if you buy one that doesn't work
Thank you for you replies , in that case i would need a sat usb tuner because my uno has a cable tuner . Does it exist which would work with uno + blackhole . Thanks
