Question about XtreamTV
im2020
I am using XtreamTV 0.0.6 from my reseller on my Vu+ Duo2 and it works fine but moving between channels is clumsy so I want to populate Category 0 Favorites with some channels from Category 8 |IPTVUK| ENTERTAINMENT.
Pressing Help shows the following message: You can add channels to the favorite when you are on the channel and press fav or txt button.
On the Vu+ Duo2 Remote Control there is no button labelled FAV or TXT. Please can you tell me how I should do it.
Thanks in advance for your help.
IanM
