Question re adding a tuner to VU Uno
encblue
Hi
A bit of a newbie question (I'm sure someone will be able to help)
I have a VU Uno twin satellite tuner receiver. Presently it has not terrestrial tuner. Can I add a terrestrial tuner easy enough? & would the RF out on it have a voltage out to operate a magic eye set up?
Cheers
Hi
Cheers
If you need both DVB-S2 and DVB-T tuners, the only way is to add a USB DVB-T tuner to your Uno box.
