billigmeister
Hi All
I am thinking of getting a vu+ duo2. My set up is as folows
I am a bit confused by all the talk of different images etc so apologise if i mix up my understanding.
My questions are as follows
a lot of questions but i think it is good to do your research prior to purchase. I think i know the answer to some of the above but i am not sure, hence my asking for clarification.
thanks in advance for any help
- LG Smart Webos TV
- dual feed from 28.2 astra (fixed)
- dual feed from 19.2 astra (fixed)
- no antenna feed
- Could i plonk in an old internal hard drive from an old Humax pvr that i have?
- Is recording to a USB portable drive easy to set up and is it as stable as internal drive once set (is there a limit to size?)
- Once recorded onto a USB, can the content and files be taken and easily viewed on other devices (ie a different smart tv or laptop) and would it still work slickly when i plug it back into the duo2?
- How easy is transcoding onto another screen device (ie would my technophobe wife be able to do it onto an ipad)
- Does transcoding allow for items from the USB portable drive be beamed to whichever device you want and still be able to record via the satellite
- how decent are the EPG's and do they all allow for series link etc? (is this image specific?)
- Would i be able to have on one epg the data from the english feed and also the german feed together?
- Are there any of the on demand services available via the duo2 (english or german)?
- I was thinking about setting kodi/xbmc on - is there a particular image that is best used for this?
- Generally with the images - is there a simple guide that demonstrates the particular positives of that particular image....to the layman they all seem get techie and not easy to choose
