Ralink MT7601U chipset
gh_n
hi angelofsky1980
i have Ralink MT7601Usta chipset wifi
the problem is with blackhole images under bh3 versions dont
work but with bh3 and higher works grate in vu+solo
because of flash limit i want to use bh 1.7.2 or 2.1.7
could you please give tested ipk file for bh image in solo ?
i have tested this thread and dosent work on solo with bh image
Ralink drivers for MT7601U devices (NOT TESTED)
and if you dont have any ipk tested tell me how can i export the whole wifi driver files from ie: bh3.0.3 and import to lower versions
TNX
waiting 4 your answer
Hi friends
I did and test it
for the first time on devices with a low-memory flash, like a vu+solo,
the 7601 cheapest which is available on the market, with black hole image of the old versions like 2.1.7 and pli 4 image
i did the perfect matching and testing here. For friends who have these models, they can prepare and and copy these files to paths
attributes folders 755
and files 644
etc / wireless
lib / modules / 3.9.6
lib / modules / 3.9.6 / kernel / drivers / net / wireless
Good luck
@Crazysat
