Ralink RT73
rom11b06
Hello,
As a recently owner of a Vu+ Uno y installed the latest image of black hole 1.6.4, after configuring the setup box for the first time, y tried put my wi-fi usb (WL-167g v2) but it doesn't recognize it.
Isn’t suppose to recognize automatically? Or should y do something else….
Thanks for any kind of help.
Hello,
I've made a google search and seems your device is supported by RT73 driver but into the driver included on BH image is not listed as supported device.
I will try to solve this issue ASAP.
Ralink has stopped support around the old RT73 chipset :(
I would also need help with this driver - installed Vu+ Duo from scratch, with BH 1.6.5, all fine. First tried with Tp-Link WiFi USB, it did not even recognize it, so I found another stick, which is based around RT73 driver, this one was nicely recognized, but I can't connect to my network. Because of range extending router which supports only WEP whole network is WEP encrypted. This USB WiFi stick works fine in a PC. Have anyone ever tried it with WEP? Does anyone know if driver in Vu supports 64bit and/or 128bit encryption? Or this maybe doesn't mater at all? Can't figure it out what's wrong, have 5 PCs in this network, few iphones ipads all connect fine through WEP, not Vu... Maybe I should try with open connection and see if encryption is a problem at all??. Name on stick is Edimax EW-7318USg
What is the name (and version) of the TPLink stick?
cat /proc/bus/usb/devices :
T: Bus=04 Lev=02 Prnt=02 Port=01 Cnt=01 Dev#= 3 Spd=12 MxCh= 0
D: Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1
P: Vendor=07d1 ProdID=3c07 Rev= 0.01
S: Manufacturer=Ralink
S: Product=802.11 bg WLAN
C:* #Ifs= 1 Cfg#= 1 Atr=80 MxPwr=300mA
I: If#= 0 Alt= 0 #EPs= 5 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none)
E: Ad=81(I) Atr=02(Bulk) MxPS= 64 Ivl=0ms
E: Ad=01(O) Atr=02(Bulk) MxPS= 64 Ivl=0ms
E: Ad=02(O) Atr=02(Bulk) MxPS= 64 Ivl=0ms
E: Ad=03(O) Atr=02(Bulk) MxPS= 64 Ivl=0ms
E: Ad=04(O) Atr=02(Bulk) MxPS= 64 Ivl=0ms
