ram usage issue
fatalizer
Hello.
i've noticed that ram usage jumps from 10-20% after a reboot to 93-95% in a few minutes...
i'm running 2.0.9.1 (had same problem under 2.0.8/9) default plugins + bitrateviewer, internal sata hd and nothing more.
could be the stream over a pc by lan?
tbh i cannot really understand whats happening.
thankyou
@fatalizer : RAM in Linux-enigma2 is for to be used. Not to be free. There is a lot written on forum about Linux RAM usage.
Don't worry, your RAM usage is OK ;).
well... ok ram its not 100% and dnt need to swap but when i get as much usage i've blackscreens for 10secs (on tv) every time i change stream channel on pc
these are details...
http://uploadffs.nl/Mbd
i still don't undersand, 13% enigma2 and all other memory where is? this check was done with decoder on standby with no ip stream or anything else
Cached memory 416.692 kB. Linux keep cache data until next request for other cache use. When the last saved data are not necessary, RAM will be used for new data.
