Realtek 8712 driver
angelofsky1980
BlackHole Driver Specialist
Here a list of future WiFi USB stick supported by BlackHole images :)
On bold the tested devices
/* RTL8188SU */
/* Realtek */
0x0BDA, 0x8171
0x0bda, 0x8173 // =
0x0bda, 0x8712 // =
0x0bda, 0x8713 // =
0x0bda, 0xC512 // =
/* Abocom */
0x07B8, 0x8188
/* ASUS */
0x0B05, 0x1786
0x0B05, 0x1791 // 11n mode disable -
/* Belkin */
0x050D, 0x945A Belkin Basic Wireless USB Adapter
/* Corega */
0x07AA, 0x0047 CG-WLUSBNM
/* D-Link */
0x2001, 0x3306 D-Link DWL-G122 Wireless G USB Adapter (rev.F1)
0x07D1, 0x3306 // 11n mode disable * D-Link DWL-G122 Wireless G USB Adapter (rev.F1)
/* Edimax */
0x7392, 0x7611 Edimax 802.11n Wireless USB Adapter
/* EnGenius */
0x1740, 0x9603
/* Hawking */
0x0E66, 0x0016 Hawking Hi-Gain USB Wireless-G Dish Adapter
/* Hercules */
0x06F8, 0xE034
0x06F8, 0xE032
/* Logitec */
0x0789, 0x0167 Logitec LAN-W150N/U2 Wireless LAN Adapter
/* PCI */
0x2019, 0xAB28 GW-USNano
0x2019, 0xED16
/* Sitecom */
0x0DF6, 0x0057 Sitecom 150N Wireless USB Adapter WL-349v2 001
0x0DF6, 0x0045 Sitecom Wireless Nano USB Adapter 150N WL-353
0x0DF6, 0x0059 // 11n mode disable *
0x0DF6, 0x004B Sitecom 150N Wireless USB Adapter WL-349v3
0x0DF6, 0x0063
/* Sweex */
0x177F, 0x0154
/* Thinkware */
0x0BDA, 0x5077
/* Toshiba */
0x1690, 0x0752
0x20F4, 0x646B
0x083A, 0xC512 // =
/* RTL8191SU */
/* Realtek */
0x0BDA, 0x8172
/* Amigo */
0x0EB0, 0x9061
/* ASUS/EKB */
0x0BDA, 0x8172
0x13D3, 0x3323
0x13D3, 0x3311 // 11n mode disable -
0x13D3, 0x3342
/* ASUS/EKBLenovo */
0x13D3, 0x3333
0x13D3, 0x3334
0x13D3, 0x3335 // 11n mode disable *
0x13D3, 0x3336 // 11n mode disable *
/* ASUS/Media BOX */
0x13D3, 0x3309
/* Belkin */
0x050D, 0x815F Belkin N Wireless USB Adapter
/* D-Link */
0x07D1, 0x3302
0x07D1, 0x3300
0x07D1, 0x3303
/* Edimax */
0x7392, 0x7612
/* EnGenius */
0x1740, 0x9605
/* Guillemot */
0x06F8, 0xE031
/* Hawking */
0x0E66, 0x0015 Hawking Hi-Gain USB Wireless-N Dish Adapter
/* Mediao */
0x13D3, 0x3306
/* PCI */
0x2019, 0xED18
0x2019, 0x4901
/* Sitecom */
0x0DF6, 0x0058 Sitecom 300N Wireless USB Adapter WL-352v2 001
0x0DF6, 0x0049 Sitecom Wireless High-Gain USB Adapter 300N X2 WL-356
0x0DF6, 0x004C Sitecom 300N Wireless USB Adapter WL-352v3
0x0DF6, 0x0064
/* Skyworth */
0x14b2, 0x3300 Skyworth DWA-130-1 Wireless N USB Adapter (rev.C2)
0x14b2, 0x3301 Skyworth DWA-130-2 Wireless N USB Adapter (rev.C2)
0x14B2, 0x3302 Skyworth DWA-130-3 Wireless N USB Adapter (rev.C2)
0x04F2, 0xAFF2 ASRock ION 3D 152D WLAN Driver
0x04F2, 0xAFF5 ASRock ION 3D 152D WLAN Driver
0x04F2, 0xAFF6 ASRock ION 3D 152D WLAN Driver
0x13D3, 0x3339 Realtek RTL8188SU Wireless LAN 802.11n USB 2.0 Network Adapter
0x13D3, 0x3340 // 11n mode disable * Realtek RTL8188SU Wireless LAN 802.11 USB 2.0 Network Adapter
0x13D3, 0x3341 // 11n mode disable * Realtek RTL8191SU Wireless LAN 802.11 USB 2.0 Network Adapter
0x13D3, 0x3310 Realtek RTL8191SU Wireless LAN 802.11n USB 2.0 Network Adapter
0x13D3, 0x3325 Realtek RTL8191SU Wireless LAN 802.11n USB 2.0 Network Adapter
/* RTL8192SU */
/* Realtek */
0x0BDA, 0x8173 Realtek RTL8192GU Wireless LAN 802.11n USB 2.0 Network Adapter
0x0BDA, 0x8174 Realtek RTL8192SU Wireless LAN 802.11n USB 2.0 Network Adapter
/* Belkin */
0x050D, 0x845A Belkin Surf & Share Wireless USB Adapter
/* Corega */
0x07AA, 0x0051 CG-WLUSB300NM
/* Edimax */
0x7392, 0x7622 Edimax 802.11n Wireless USB Adapter
/* NEC */
0x0409, 0x02B6 NEC 802.11n Wireless USB Card
Hey, I got a wifi dongle but can't seem to get it loaded.
dmesg is showing that it finds it and so on, but I can't see it under 'ifconfig'. Here is the cat:
T: Bus=02 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#= 2 Spd=480 MxCh= 0
D: Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1
P: Vendor=050d ProdID=1102 Rev= 2.00
S: Manufacturer=Realtek
S: Product=802.11n WLAN Adapter
S: SerialNumber=00e04c000001
C:* #Ifs= 1 Cfg#= 1 Atr=80 MxPwr=500mA
I: If#= 0 Alt= 0 #EPs= 4 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none)
E: Ad=81(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=02(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=03(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=84(I) Atr=03(Int.) MxPS= 64 Ivl=125us
The Vendor string seems to match the one you posted:
/* Belkin */
0x050d (yes it's a belkin dongle)
Am I missing something? I can 't find the setting to 'turn wifi' on in enigma either.
/* Belkin */
I've looked on the web and seems that your device is supported by RTL8192 driver who is already included into BH images but the IDs of your device aren't included.
I will make a patch to include them.
You can look HERE for IPK update and report if works or not, thanks :)
/* Belkin */
Works perfectly, many thanks on the quick response :)
For anyone that reads this, remember to reboot after installing to initiate the new driver, else it wont show in the network settings.
Over and out.
I've tested succesfully the Hercules Wireless N USB Mini HWNUm-300 (Realtek RTL8191SU)
Very good work. Thanks. :notworthy:
