Realtek rtl8188eu UPDATED driver for new Vu+ kernel
angelofsky1980
BlackHole Driver Specialist
In this thread there is the IPK for all Vu+ boxes that contains Realtek rtl8188eu chipset.
Installation instructions:
PREREQUISITE for Solo2, SoloSE, Zero and Duo2 users:
via telnet/SSH connection you must launch this command:
opkg remove kernel-module-r8188eu --force-depends
After that, continue with the following steps:
a) put the IPK into a USB pendrive and connect it to your box. You will have the possibility to install IPK directly.
b) put the IPK into /tmp folder of your box and use the "Manual install IPK package" from BH Green Panel -> Yellow Button.
Supported devices will be avaiable on the second post of this thread.
Drivers will be avaiable on the third post of this thread after compilation for all supported boxes.
angelofsky1980
Supported devices taken from driver source code.
If you have a device compatible with this driver but it's not listed here, open a support request here.
Thanks
        /*=== Realtek demoboard ===*/
        {USB_DEVICE(USB_VENDER_ID_REALTEK, 0x8179)}, /* 8188EUS */
        {USB_DEVICE(USB_VENDER_ID_REALTEK, 0x0179)}, /* 8188ETV */
        /*=== Customer ID ===*/
        /****** 8188EUS ********/
        {USB_DEVICE(0x07B8, 0x8179)}, /* Abocom - Abocom */
        {USB_DEVICE(0x0DF6, 0x0076)}, /* Sitecom N150 v2 */
        {USB_DEVICE(0x2001, 0x330F)}, /* DLink DWA-125 REV D1 */
        {USB_DEVICE(0x2001, 0x3310)}, /* Dlink DWA-123 REV D1 */
        {USB_DEVICE(0x2001, 0x3311)}, /* DLink GO-USB-N150 REV B1 */
        {USB_DEVICE(0x056E, 0x4008)}, /* Elecom WDC-150SU2M */
angelofsky1980
Vu+Duo / Vu+Solo / Vu+Uno / Vu+Ultimo / Vu+Solo2 / Vu+Duo2 / Vu+SoloSE / Vu+Zero IPKs
  • rtl8188eu_git-r2-bh3_bm750.ipk
  • rtl8188eu_git-r2-bh3_vuduo2.ipk
  • rtl8188eu_git-r2-bh3_vusolo.ipk
  • rtl8188eu_git-r2-bh3_vusolo2.ipk
  • rtl8188eu_git-r2-bh3_vusolose.ipk
  • rtl8188eu_git-r2-bh3_vuultimo.ipk
  • rtl8188eu_git-r2-bh3_vuuno.ipk
  • rtl8188eu_git-r2-bh3_vuzero.ipk
gggabcsi
I can confirm, that driver is tested, exactly this device, below working without any issues!
Thank you for the grate support.
Kantila
Hello,
I have Vu+ Zero and Black Hole 2.1.5, i see in changelog :
- WIFI: update driver RTL8188EU
- WIFI: update driver RTL8812AU
So if for example i want use one of those drivers :
I need or not install IPK ?
Thank's
angelofsky1980
Hello,
Thank's
Drivers should be already included into latest BH images.
shambar
after i select the wlan and scan the AP, i got the answer that there is on AP so connect. Im using dlink wifi on vu+ solo with black hole image. Any ideas?
angelofsky1980
_james_
Driver for chipset rtl8188eu have been included into all BH images and works properly.
I've bought in the past a WN725 v2.1 for testing purposes only and work properly.
Thanks @angelofsky1980 , yes is working fine on BH images, and with OpenBH?
The only problem is that i cant add the real mac address + fixed IP to the router from that wifi pen WN725 v2.1
see the images if i really can explain to you
so i cant add a real fixed IP do my zero and router, if i made any changes @ vuzero, always stay online/ative on my wifi network because the mac address is not the same.
Why?
Im using now Black Hole 3.0.2.F and 2.1.6 before
Giuseppe_80
Hi to everybody, yesterday i've installed BH 3.0.3-vuzero...I bought a inexpensive wifi usb dongle TL-WN725N_V2.2 ...Driver for chipset rtl8188eu have been included into all BH images but doesn't works properly...wifi works but with a really slow connection even if distance is 2 meter to the router. This is too slow to watch Videos, while with ethernet it goes very fast and with good quality.
So, I run:
it sais that there aren't any package to remove.
And after i run:
opkg install rtl8188eu_git-r2-bh3_vuzero.ipk (ipk that you provided) and it sais:
opkg_install_pkg: Package rtl8188eu md5sum mismatch. Either the opkg or the package index are corrupt. Try 'opkg update'.
* opkg_install_cmd: Cannot install package rtl8188eu.
What can I do? I've to buy another wifi dongle?
What do you suggest?
Thanks a lot.
tamicia
Ti sbagli:
I driver sono gia presenti nella 3.0.8 sul mio Vu+solosev2 ma l'adattatore wifi non viene riconosciuto.
Ho provato poco fa con la tl-wn725n ricevuta oggi con risultato negativo:
- il comando "opkg remove kernel-module-r8188eu --force-depends" non rimuove nulla nonostante siano gia preinstallati.
-se provo ad installare il driver che hai postato (per solose) non installa un bel nulla, come gia scritto un utente (Giuseppe_80) quasi 2 anni fa senza avere supporto:
PS: l'adattatore wireless è un v.3
