Reboot issue - Solo2
superfurryallan
Hi All,
I am experiencing issues everytime i try to reboot the box. It seems to hang on reboot. If i power the box off using the physical switch and power back on, i have no problem at all.
looking to try and resolve this as it effectively means i cannot power cycle the box remotely.
Regards
Allan
I should add that I also have the transmission web client running with no problems, and when i reboot i can connect to this remotely, so i think it seems to be an issue with openwebif
It is a problem that seems to occur after an epg refresh.
However it is something that OpenPLi team need to fix as the problem is in there coding (which OpenBlackHole is based on).
