Recommendation WIFI USB for Vu+ UNO 4k
perics
Hi.
I would appreciate it if you can recommend me what USB WIFI to buy for my VU + one 4k with BH latest version installed.
Better if its a common brand, so i can found it easily here in Spain. I dont have coverage problems, so as small and cheap as posible.
Thanks!
Hi.
Thanks!
Better idea is that you put here some brand and models found around you ...
Hi!.
Is NETIS WF2190 compatible with Vu+ solo 4k?
I also saw: COMFAST WiFi USB CF-912AC and TP-Link Archer t4u ac1300
Thanks a lot!
Perics
NETIS WF2190
It should be supported. It uses 8812au driver.
TP-Link Archer t4u
Depends on hardware revision:
v1: It should be supported. It uses 8812au driver.
v2: It should be supported. It uses 8812au driver.
v3: Actually not supported. It has Realtek 8812BU chipset
H: It should be supported. It uses 8812au driver.
Hv2: It should be supported. It uses 8812au driver.
HP: It should be supported. It uses 8812au driver.
I wonder why, now that powerlines are much cheaper than in the past, one would put himself in troubles using wifi adapters, needing drivers and so on.
