Recording folders?
no66
Been running Pli up until today. Got BH right now. Looks good, but a questinon.
How do I use different recording folders in BH?
I have set folders by FTP and used these in Pli. You can choose the folder you want you recording to go to in the timer.
Thanks
Matrix10
Thanks
I think you can .
You have to make different Bookmarks
System Menu >> Recording paths >> OK>>Menu>> button (1) choose a new location for recording>>Blue Add Bookmark
Now you can choose in Recording paths defaults (default REC location)
and in the TIMER Location you like to record.
Of course now you have to use Media player or some of the movie plugins (I have not test)
but not Movie Player for not default REC location.
Mito
This time you are wrong :D
You can use the usual way to play the recordings.
When you are into the recording list, you can select another directory pressing the "recordings list" button on remote.
Matrix10
You can but It's not elegant :victory:WELLA.....
and is not intended as a filebrowser such as the file list in Media Player but to select default movie path???
