Recording issue
I do not watch any other program when I set the timer to start. Having been at times when I'm not home or select the sleep
Try to program recording, put the box in standby, let the TV on and watch, what will happen at the beginning of recording..
Well it will defo indicate if its a hardware fault then m8
Hi just an update,
Have checked both tuners A and B separately and both are working fine no problem, have tryed changing the tuner configs from both A and B to simple and single to A simple/single and B equal to A and still nothing
It's weird that it's bed fine over the past week and suddenly it's happened, any advise would be appreciated
Thanks
Hi just an update,
Thanks
Are you on the latest image? Cus it may be a case of a reflash. Cus you've ruled out any possible hardware faults now. Maybe something you've installed has messed things up. I'd try latest image and see if it records before installing extra plugins etc
I have BH 2.0.5 and I'm sure that's the latest, if not do you know where I could get the latest image and instructions of how to do a full image backup including channel lists etc and also how to reflash?
Thanks
Thanks
Latest is 2.0.6 rev b mate. What vu stb do you have?
Save to HDD mate. After reflash it will ask you to restore stb settings and select yes......
Follow those instructions and don't use personal backup etc cus it won't work
Ok mate, thanks for your help, will update this and hope it works
Here is another suggestion.
After you have done some test, the problems may relate to settings or/and crupted system file. According to my experence, re-instore an old setting only when you are sure the the backup-setting is prefect-issue-free. If I were you, I will do a fresh flashing and fresh setting (I knew it will cause you much more time) first with just basic setting. Then testing your hardware as you wished. If no problem, you can re-install your previouse settings. Just a suggestion.
