recording on computer harddisk problems
i m using vu+solo with installed image of blackhole 2.0.5 i mounted my usb (32 gb) to my receiver
and can easily record but when i try to record on my computer harddisk i got the following error
IN ORDER TO RECORD A TIME , THE TV WAS SWITCHED TO THE RECORDING SERVIE
and when i reboot my reciver i got the following message
RECORDING(S) ARE IN PROGRESS OR COMING UP IN A FEW SECONDS!
REALLY REBOOT NOW
YES
NO
i want to to tell before going to record on my computer harddisk i first brwose my compter then go to recording paths to locate my computer directory and save it
even then i m unable to record and got the above mentioned error which i highlighted in capital writings
plz help how to record on computer hard disk
what op system you use on your PC? PC movie folder must be mounted first on your vu and visible by your box.
I do not recommend to use any of computer drives mounted over the network as a destination for recorded movies.
alot of thanks my dear brother as i created movie folder the problem solved
thanks , thanks , thanks , and 100000 times likes and thanks for u
God bless u
