Ev0
Admin
The problem start from images BlackHole version 2.1.1 !
That was when the kernel was updated, as @>>Artorius<< says, this is not a problem with the image or your box, it's the software you have added that is the issue.
@Artorius...I don't know which people you mean, but I can tell you that I'm not using any "software" to view any card..I'm watching FTA channels and that's more than enough for me, but STILL the record function won't work. I'm now using BH 2.1.3 and before with 2.0.9 there was never problems...also not with earlier versions if you ask me! So now you know where I stand!
Hi!
I have also this problem with Blackhole 2.1.1 and later.....its not working with both tuners! 101% genuine box! I use openpli instead and wait for a fix to come for this problem.
You haven't explained nothing about reproduce your problem so it's a non-problem.
I've tested recordings from SAT (2 tuners used) and USB DVB-T and all works regularly. BH 2.1.4.
No details = no help.
The problem is that i can´t use both tuners at the same time. For exampel the pip funktion and record a program when i look on another. NOT working from BH 2.1.1
Can only use one tuner......
I cannot help you ... In my installation both tuners work correctly and I can use them togheter.
More details are welcome to reproduce your problem.
I think it could be the kernel version or something llike that? in BH 2.1.1 they change it:
Black Hole 2.1.1
By Black Hole
By Vu+
- New skin MX SkyLine SE
- Add new Crypto systems in OSD: Biss, Bulcrypt, Betacrypt, PowerVu (By Ev0)
- Add parental control in Bh extra settings panel
- HbbTV enabled by default for Duo2, Solo2, SoloSE, Ultimo
- Removed mytube plugin (can be installed from BhSpeedUp)
Kernel:
Drivers:
- Update Kernel 3.13.5(solo2, duo2, solose)
- Update Kernel 3.9.6(duo, solo, uno, ultimo)
20140715(duo, solo, duo2, solo2, solose)
20140716(uno, ultimo)
- - Support SoloSE
- - Switch to Kernel 3.13.5 (solo2, duo2, solose)
- - Switch to Kernel 3.9.6 (duo, solo, uno, ultimo)
- - Fix sound drop in radio channel
- - Improve PIP (solo2, duo2, solose, Needs E2 update)
- - Allocate more memory to linux (duo2)
- - Improve media playback
And in BH 2.1.0 they fix something with dual tuners:
Black Hole 2.1.0
Drivers update:
- New skin by Matrix MX X Line
- New plugin Fast OpenEpg
- Updated Crossepg to the latest 0.81 version
- Updated OpenWebIf
20140424
- Fix multichannel audio problem(solo2, duo2)
20140418
- Fix DVB-S2 Single(AVL6211) tuner problem(duo2, ultimo)
- Change nim_sockets of DVB-T2 tuner(duo2, needs a E2 update)
20140403
- Fix audio problem(duo2, solo2)
20140318
- Fix dual tuner lock problem(duo2, uno, ultimo)
- Fix PCM multichannel from standby(duo2, solo2)
20140316
- Fix DDP problem(duo2, solo2)
Again, you have not posted a series of operations that can be used to reproduce your problem. No case test = no help.
A problem can exists of course and you have two ways now:
1. post here some useful informations to make reproduceable your issue and, if confirmed I'll open directly to Vu+ a ticket for help with some tech data (in the past the Vu+ Dev Team has solved some bugs with this system)
2. open yourself a bug request (www.vuplus.com) and cross fingers.
Now take your choice.
