Recording question
fizzz33
Thinking of buying a Duo 2 with 2 x twin S2 tuners question is with 2 LNB's in 1 to each tuner can you record more than 2 channels at once while watching another? If so how many can you record at once as it states you can record 16 channels if you have the right amount of LNB's in.
With 4 tuners you can record 3 transponders, and view others, when using 4 separate LNB feeds, but you can also record multiple channels, using the same transponder, which could give you the maximum of 16.
