Recording troubles
Jan Suhr
Sometimes a recording doesn't record to hdd for me.
It is a time recording saved from the EPG panel reached from hitting number 3 button when in EPG list.
I get the message on the TV that the recording is starting, the little red dot in the corner is showing during the recording on the LCD and in the Timer menu it is shown that the recording is in progress. I have 191 Gb of free space on the disc.
When the recording is ended I have 0 (zero) seconds of recorded program.
It has happened a few times and in between the recording has worked. There are free tuners when the recording is started. My setup is with 4 tuners.
What can be the problem?
Thanks
Jan
This has happened to me once... Not sure what happened...
BTJ
Sent from my Nexus 5 using Tapatalk
