Duo / DuoLE red led again....
barbatrukko
Hello,
I own a Vu Duo. A few years ago (at least 2 I suppose) I had to replace the famous capacitor, what once "broken" meant that the system did not start any longer and stay with the red led on.
Since then everything has been working regularly.
I've been away for a week and for the first time I turned off the power.
On my return, I turn it on again and start to loop (it comes up to start the gui, then before the channel is rebooted, infinitely).
I turned it off. Day after I tried to turn it on again, no longer in the loop, but the red led remains on.
I thought the capacitor was "discharged" too mouch and broke again. Could be?
If I press the buttons on the remote control the intensity of the LED changes ....
Is he always guilty?
UPDATE: After 4 hours system started again (I think capacitor charged slowly....)
Dead.... no more start......
I think to buy new one Duo2
I see that some model have twin sat in the same slot. I can put unicable over only one connector adn by software configuration connect "logically" also to connector 2 ?
