Red led problem for VU+ uno
baset_mohreb
helo to every body
I have this problem wich is STB will not start or boot only the red led will show i tried to flash it weith vu uti tools by serial cable but no can do , plesssss help "S O S"
"THANKS IN ADVANCE "
helo to every body
What is the last operation you have done on your STB?
thank you for response
my last was i flashed it with the BLACKHOLE inmage 1.7.4 but not for uno i think for ulitmo when i reboot the STB did not work at all just the red lamp plsssssss help
Uhm.... Why do you have manually managed images files for another box?
With serial interface you can look what happen when the box startup..
first of all it is an Accident , show me how can you do that "how to use the serial"
You need a null-modem cable and a software called Terminal Emulator like Hyperterminal or Minicom.
Connect PC & STB, open Terminal emulator software, establish connection on COM port and then turn ON box.... and cross fingers if something appear on screen....
