Registrazioni su Hdd
It is simply.
The better way i think is:
1) goto blue panel -> black Hole Extra Settings -> Network Browse & Mountpoints
2) Scan your network and your second Vuduo will find.
3) Select the box, (don't assign a password and then select the Nfs type
4) Leave all the settings as default
5) Save.
Now you can go in MediaPLayer and you will find in it the hard disk of the Your second Duo Box.
Select the registration you want to watch and play it.
You can use this procedure for both the boxes.
It is simply.
5) Save.
Ok grazie funziona tutto.
