Release: Cubic 1.2.0 for VU+
tae
English:
VU+ with 3.1.1 Kernel
Driver Date: 28.02.2012
OE Date: 28.032012
DVBAPP Date: 28.03.2012
  • Neu: Cubic HD Skin
  • Neu: Cubic Panel has now a version specification (Currently, the panel v.1.2.4)
  • Neu: Cubic Panel About shows now some image information more (Imageversion, Branch, Kernel, Hardwaretype)
  • Neu: Menu to run directly Scripts on the panel Cubic
  • Neu: Cronmanager to execute scripts timebased
  • Neu: ext4 Support (New devices are now formated as ext4 Formats)
  • Neu: Crashlog Reporter - Crashlogs sends directly to the developers from Cubic (at Cubic Panel Disabled. You kann activated them if you want use this)
  • Neu: Shareinfobar with **** Support (On / Off switchable)
  • Neu: Own Second Infobar (If a foreign Skin will bring the part will be ignore our SecondInfoBar)
  • Neu: epg.dat can be stored on USB
  • Neu: openWebIF in the Image
  • Fix: Cam is active display shows nothing if no cam is active. Now displays "no cam running"
  • Fix: If the CamName is too long, this entry is cut off
  • Fix: Some translations in Cubic Panel
  • Fix: Information function in the device manager now works
  • Änderung: Offline Installer has now a GUI restart query
  • Änderung: Online Addon Installer has now a GUI restart query when an addon was installed or updated.
  • Änderung: Altered newsfeed reader
  • Änderung: Modified software manager (Shows now modules and settings)
  • Änderung: New Swap Managment
  • minor fixes in various files!
  • unnecessary Pyhton code in our files deleted
  • Support of VU+ Backupsuite (Plug-in is on the feed)
  • Support of nano
  • ONLY on Cubic VU+ (Not on Cubic Dreams) : Support for relative skin coordinates ( 'c' and 'e' ) Thanks at pieterg for thePatch
Thanks to all users who give us their feedback.
Thanks to all supporters in the background.
Thanks to openee for the Basecode of the DeviceManager.
Thanks to the project E2OpenPlugins. We hope we will soon be able to give something back to the Community.
Thanks to pieterg for his relative Coordinates Patch .
Thanks to vlamo for nice Ideas and good Work.
السلام عليكم موضوع مميز تشكر عليه
وعليكم السلام​
الاخ حسن رجب لامانع من الكتابة بالعربي ولاكن يجب وضع اترجمة باللغة الانجليزية او الافضل الكتابة بالإنجليزي حتى يتمكن أعضاء الفريق من المساعدة
ولك شكرى
وأهلا بك
Dear Hassan, this is the international support section, so please write in English!
So you can get the proper support!
تحياتي
RgdZ
a911
yes here are some pics from that image!
