Remote channel stream converter problem
Jules
Hi all,
I have installed Remote channel stream converter to a Duo 1.
Channels download OK but then after a few seconds the downloaded channel list becomes unselectable
and unhighlighted, so not able to select a channel.
I have tried reloading but always ends up the same.
Hope someone can help please?
Thanks everyone.
Take care,
Juels.
Duo 1 is a client of which box? What image is on Duo 1 and what image and box server?
What type of network connection do you use? Cable or wifi?
Sorry, downloading channels from another duo 1 on same LAN
but through ethernet homeplug.
Thanks
In the customer box you must use OBH ... these boxes have been around for a few years.
Then in the client box you must use the network tuner. Install OBH in the client box and configure the network tuner;
Menu-Setup-Tuners & Scanning - Fallback configuration
The IP is from the box server, the port is 8001 (maybe it will appear differently from what I have, like the name of the box server).
If the client box is not connected to an antenna, do not configure its tuner.
The box server does not need any configuration.
We don't help with clone receivers. They are of poor quality and unlikely to perform as well as genuine receivers, with better quality parts.
