Hello,
I have following issue with my RC for Uno. The other day RC started behaving bit strange, when pressing same button twice it does not execute the command twice. For example to get out of submenu tuner config you press exit twice but my RC does not respond to second exit button pressing. I have to press other button and then again exit button.
So I took the RC from father's Ultimo 4k and everything works great. So I bought new RC for Uno and it does the same thing! Does not respond to second press of same button. I am sad.
What do you think?
All three RCs look physically same. No change in my household, no gadgets or furniture. Batteries were my first action.
The second press simply does not work. I can wait 20 seconds after first press and no response. But I press other button and immediate reaction. No new image loaded.
You did not even tell us what image are you using... How could we tell you that?!?
But, I think it's impossible it's the reote control code, otherwise nothing would work.
It was just to check everything possible.
So after doing some experiments, having no success I did the last thing. I bought brand new batteries and....it worked.
I feel stupid.
Nevertheless I do hope if you guys see my other questions in future, you will not skip them.
Big thanks to all of you but mostly to elector.
The beer is on me.
