remote control problem
hunterxyamani
Hello, i have a problem with the remote control on my vu plus solo 2 i tried all the BH 2.x.x images and the problem still the same, i tried also to use another remote control ( from my solo 1 it's look the same ) and it doesnt work either :/ the only thing work is the remote control from the android application.
The remote control codes from your solo is diferente for solo2.
To program one of your remotes to work with your solo2, try this:
Extracted from user´s manual for solo2 ( Official VUPLUS webpage )
Procedure:
On your remote control press:
1) - <2> and <7> simultaneously
2) - Press <HELP>
3) - <0> <0> <0> <0>
Note: Test and reply if it works!
