Remote Control problem
Basshunter
Hi! Can anybody help me with this problem ?! I'm using VU+ Uno 4K SE and have some problems with the Remote Control. When I'm using the plugin Chromium, I can't change the RC-layout from numbers to characters. If I push the yellow key, the Chromium Virtual Keybord appears and I can choose the characters I will, but either the enter-key or the green key move the text to the browser.
The settings are: Main Menu/Setup/System/Remote Control Code/RC Type = New VU+ Type 6 RCU
RC System Code = 2 Text support = yes
