Remote Control problems
DBGT
Salam
i just upgrade to BlackHole Vu+Duo 1.6.4 Full Hdmi-Cec.
before when i was using v1.6 when i press OK button the channels list show up (its normal), but now when i press OK button the info bar of the channel show up.
anyone know how to fix this issue? i change my keyboard to English and Deutch but nothing changed.
In which directory is the keymap file stored - i would like to edit this file to modify certain keymaps such as 'blue' button. I am running blackhole 1.6.4 - I would like to also use a different skin from the default - It looks to me that the functions of keymaps are skin specific ?
If you edit keymap for a blue button you will lose access to some bh pannels and functions.
Best is to use a multiquick button plugin where you can edit function of some button (my advice is not to touch green and blue button because of their functions in BH image).
thanks for the response and i understand the danger (famous last words...) I specifically want to disable the 'blue'and 'green' buttons and assign a keysequence route to these menus. Where is the keymap file found?
