Remote control
Richy42
Hi
I bought a ir300 remote control for my vu duo box. When I try the code below nothing happens. The led light doesn't come on after pressing 2and 7.
Any ideas thanks
press buttons no. 2 and 7 altogether. The LED bulb will light on.
Press "help" button
Press 0001
Hi
Any ideas thanks
Press "help" button
Press 0001
You are setting it the wrong way ( Old command setting ) :(
You must read and set it, according the manual we have posted here -->
