Remote Freeze
Glav
Hello
Does any know what to do when the box freezes when using the remote. This is a little odd but sometimes when using the remote, pretty much doing anything, the box freezes. The channel I'm watching keeps working but what ever GUI screen I bring up using the remote stays, the remote won't work and I've to reboot to get it to work again. BH Hyperspace V 2.05.
Thanks
Hello
Thanks
You don't specify what box do you use but check RC batteries and also if there are IR interferences near your box
Sorry angelofsky1980, thought as I was in Duo2 Black Hole Image that was a cert. Anyway it is a Vu+ Duo2 box, now just 3 days old and brand new batteries. The IR interference might be it as I've got a system in place that allows me to control the box from any room, would that be what your thinking is, that the IR emitter is somehow bouncing the signal?
I suggest to use the box without the IR amplifier or similar one to determine if it's the problem
Solved, I was using backup BH image which is not good idea. I installed official BH 2.0.6 and installed ******, plugins and addons separately and all problems solved.
Thanks
warning
read the forum rules
