Remote option
alom23
hi. i am trying to use 2 vu boxes in 1 room . so my problem is controlling them . is ther an option to change remote setting on the box so that booth boxes dont get the same command ? in clarketech et900 on ct image they have an option to use original remote or dreambox remote . i was wandering if a plugin to use on vu with your image ? ................ any thoughts on it
Thanks
Thanks
I think you can only use an universal remote control like Logitech.
You could try this, via software manager and the packet management you can download this plugin
dvbapp2-plugin-extensions-multirc
Let us know if it works.
